Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; 1:R3=2 ; 1:R4=2 ; z=2"
ARM LB+data+data-wsi-rfi-pos-addr-po001 "DpDatadW Rfe DpDatadW Wsi Rfi PosRR DpAddrdW PodWW Rfe" Cycle=Rfi PosRR DpAddrdW PodWW Rfe DpDatadW Rfe DpDatadW Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpDatadW Wsi Rfi PosRR DpAddrdW PodWW Rfe { %x0=x; %y0=y; %y1=y; %z1=z; %a1=a; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%y0] | STR R1,[%z1] ; | MOV R2,#2 ; | STR R2,[%z1] ; | LDR R3,[%z1] ; | LDR R4,[%z1] ; | EOR R5,R4,R4 ; | MOV R6,#1 ; | STR R6,[R5,%a1] ; | MOV R7,#1 ; | STR R7,[%x1] ; Observed 0:R0=1; 1:R0=1; 1:R3=2; 1:R4=2; z=2;
