Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; x=2 ; y=2"
ARM LB+PPO0373 "PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpCtrldW PosWW" Cycle=Rfe PosRR PosRW PosWR DpCtrldW PosWW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWW PosWR PosRW PosRR Pod*W DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpCtrldW PosWW { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | MOV R2,#2 ; STR R1,[%x0] | STR R2,[%x1] ; | LDR R3,[%x1] ; | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%y1] ; | MOV R5,#2 ; | STR R5,[%y1] ; | MOV R6,#1 ; | STR R6,[%z1] ; Observed 0:R0=1; 1:R0=1; x=2; y=2;
