Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; y=2 ; z=2"
ARM LB+PPO0370 "PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW PosWW" Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW PosWW PodWW Relax= Safe=Rfe PosWW PosWR Pod*W DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW PosWW { %a0=a; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; } P0 | P1 ; LDR R0,[%a0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%x0] | STR R1,[%y1] ; | MOV R2,#2 ; | STR R2,[%y1] ; | LDR R3,[%y1] ; | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%z1] ; | MOV R5,#2 ; | STR R5,[%z1] ; | MOV R6,#1 ; | STR R6,[%a1] ; Observed 0:R0=1; 1:R0=1; y=2; z=2;
