Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0226 "PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrldW" Cycle=Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrldW PodWW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRR Pod*W DpAddrdR DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpDatadW PosWR DpAddrdR DpCtrldW { %b0=b; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; %b1=b; } P0 | P1 ; LDR R0,[%b0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%x0] | ADD R2,R2,#1 ; | STR R2,[%y1] ; | LDR R3,[%y1] ; | EOR R4,R3,R3 ; | LDR R5,[R4,%z1] ; | CMP R5,R5 ; | BNE LC00 ; | LC00: ; | MOV R6,#1 ; | STR R6,[%a1] ; | MOV R7,#1 ; | STR R7,[%b1] ; Observed 0:R0=1; 1:R0=1;
