Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0203 "PodWW Rfe DpDatadW Rfe PosRR DpAddrdR PosRR DpDatadW" Cycle=Rfe PosRR DpAddrdR PosRR DpDatadW PodWW Rfe DpDatadW Relax= Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe PosRR DpAddrdR PosRR DpDatadW { %a0=a; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; } P0 | P1 ; LDR R0,[%a0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | EOR R2,R1,R1 ; STR R1,[%x0] | LDR R3,[R2,%y1] ; | LDR R4,[%y1] ; | EOR R5,R4,R4 ; | ADD R5,R5,#1 ; | STR R5,[%z1] ; | MOV R6,#1 ; | STR R6,[%a1] ; Observed 0:R0=1; 1:R0=1;
