Executions for behaviour:
"1:R0=1 ; 1:R3=0 ; 1:R4=0 ; x=1"
"1:R0=0 ; 1:R3=1 ; 1:R4=0 ; x=1"
"1:R0=1 ; 1:R3=1 ; 1:R4=0 ; x=1"
"1:R0=0 ; 1:R3=2 ; 1:R4=0 ; x=1"
"1:R0=1 ; 1:R3=2 ; 1:R4=0 ; x=1"
"1:R0=1 ; 1:R3=0 ; 1:R4=1 ; x=1"
"1:R0=1 ; 1:R3=0 ; 1:R4=2 ; x=1"
"1:R0=0 ; 1:R3=1 ; 1:R4=2 ; x=1"
"1:R0=1 ; 1:R3=1 ; 1:R4=2 ; x=1"
"1:R0=1 ; 1:R3=0 ; 1:R4=0 ; x=2"
"1:R0=0 ; 1:R3=1 ; 1:R4=0 ; x=2"
"1:R0=0 ; 1:R3=2 ; 1:R4=0 ; x=2"
"1:R0=1 ; 1:R3=2 ; 1:R4=0 ; x=2"
"1:R0=1 ; 1:R3=1 ; 1:R4=1 ; x=2"
"1:R0=0 ; 1:R3=2 ; 1:R4=1 ; x=2"
"1:R0=1 ; 1:R3=2 ; 1:R4=1 ; x=2"
"1:R0=1 ; 1:R3=0 ; 1:R4=2 ; x=2"
"1:R0=1 ; 1:R3=1 ; 1:R4=2 ; x=2"
ARM DETOUR0806 "DMBdWW Rfe PosRR DpAddrdR DetourR Fre" Cycle=Rfe PosRR DpAddrdR DetourR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PosRR DpAddrdR DetourR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%x2] ; DMB | EOR R2,R1,R1 | ; MOV R1,#1 | LDR R3,[R2,%x1] | ; STR R1,[%y0] | LDR R4,[%x1] | ; Observed 1:R0=1; 1:R3=0; 1:R4=0; x=1; and 1:R0=0; 1:R3=1; 1:R4=0; x=1; and 1:R0=1; 1:R3=1; 1:R4=0; x=1; and 1:R0=0; 1:R3=2; 1:R4=0; x=1; and 1:R0=1; 1:R3=2; 1:R4=0; x=1; and 1:R0=1; 1:R3=0; 1:R4=1; x=1; and 1:R0=1; 1:R3=0; 1:R4=2; x=1; and 1:R0=0; 1:R3=1; 1:R4=2; x=1; and 1:R0=1; 1:R3=1; 1:R4=2; x=1; and 1:R0=1; 1:R3=0; 1:R4=0; x=2; and 1:R0=0; 1:R3=1; 1:R4=0; x=2; and 1:R0=0; 1:R3=2; 1:R4=0; x=2; and 1:R0=1; 1:R3=2; 1:R4=0; x=2; and 1:R0=1; 1:R3=1; 1:R4=1; x=2; and 1:R0=0; 1:R3=2; 1:R4=1; x=2; and 1:R0=1; 1:R3=2; 1:R4=1; x=2; and 1:R0=1; 1:R3=0; 1:R4=2; x=2; and 1:R0=1; 1:R3=1; 1:R4=2; x=2;
