Executions for behaviour:
"1:R0=0 ; 1:R2=1 ; 1:R3=0 ; 1:R4=0"
"1:R0=0 ; 1:R2=1 ; 1:R3=0 ; 1:R4=1"
"1:R0=1 ; 1:R2=1 ; 1:R3=0 ; 1:R4=1"
ARM DETOUR0688 "DMBdWW Rfe DpAddrdR DetourR DpCtrlIsbdR Fre" Cycle=Rfe DpAddrdR DetourR DpCtrlIsbdR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpAddrdR DetourR DpCtrlIsbdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; %z2=z; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%z2] ; DMB | LDR R2,[R1,%z1] | ; MOV R1,#1 | LDR R3,[%z1] | ; STR R1,[%y0] | CMP R3,R3 | ; | BNE LC00 | ; | LC00: | ; | ISB | ; | LDR R4,[%x1] | ; Observed 1:R0=0; 1:R2=1; 1:R3=0; 1:R4=0; and 1:R0=0; 1:R2=1; 1:R3=0; 1:R4=1; and 1:R0=1; 1:R2=1; 1:R3=0; 1:R4=1;
