Test DETOUR0678
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R4=0"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 1:R4=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=2 ; 1:R4=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=3 ; 1:R4=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=3 ; 1:R4=1"
ARM DETOUR0678
"DMBdWW Rfe DetourR Fri Rfi DpCtrlIsbdR Fre"
Cycle=Rfi DpCtrlIsbdR Fre DMBdWW Rfe DetourR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DetourR Fri Rfi DpCtrlIsbdR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
 P0           | P1           | P2           ;
 MOV R0,#1    | LDR R0,[%y1] | MOV R0,#2    ;
 STR R0,[%x0] | LDR R1,[%y1] | STR R0,[%y2] ;
 DMB          | MOV R2,#3    |              ;
 MOV R1,#1    | STR R2,[%y1] |              ;
 STR R1,[%y0] | LDR R3,[%y1] |              ;
              | CMP R3,R3    |              ;
              | BNE LC00     |              ;
              | LC00:        |              ;
              | ISB          |              ;
              | LDR R4,[%x1] |              ;
Observed
    1:R0=2; 1:R1=0; 1:R3=3; 1:R4=0;
and 1:R0=2; 1:R1=0; 1:R3=1; 1:R4=1;
and 1:R0=1; 1:R1=0; 1:R3=2; 1:R4=1;
and 1:R0=1; 1:R1=0; 1:R3=3; 1:R4=1;
and 1:R0=2; 1:R1=0; 1:R3=3; 1:R4=1;
