Executions for behaviour:
"0:R0=0 ; 1:R0=1 ; 1:R1=0"
"0:R0=1 ; 1:R0=1 ; 1:R1=0"
"0:R0=0 ; 1:R0=2 ; 1:R1=0"
"0:R0=1 ; 1:R0=2 ; 1:R1=0"
"0:R0=1 ; 1:R0=0 ; 1:R1=1"
"0:R0=1 ; 1:R0=1 ; 1:R1=1"
"0:R0=1 ; 1:R0=2 ; 1:R1=1"
"0:R0=1 ; 1:R0=1 ; 1:R1=2"
ARM DETOUR0276 "DpDatadW Rfe DetourR PosRR DpCtrldW Rfe" Cycle=Rfe DetourR PosRR DpCtrldW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourR PosRR DpCtrldW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 ; EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] ; ADD R1,R1,#1 | LDR R2,[%y1] | ; STR R1,[%y0] | CMP R2,R2 | ; | BNE LC00 | ; | LC00: | ; | MOV R3,#1 | ; | STR R3,[%x1] | ; Observed 0:R0=0; 1:R0=1; 1:R1=0; and 0:R0=1; 1:R0=1; 1:R1=0; and 0:R0=0; 1:R0=2; 1:R1=0; and 0:R0=1; 1:R0=2; 1:R1=0; and 0:R0=1; 1:R0=0; 1:R1=1; and 0:R0=1; 1:R0=1; 1:R1=1; and 0:R0=1; 1:R0=2; 1:R1=1; and 0:R0=1; 1:R0=1; 1:R1=2;
