Executions for behaviour:
"0:R0=0 ; 1:R0=0 ; 1:R2=4 ; 2:R0=0 ; 2:R2=3 ; y=1"
"0:R0=0 ; 1:R0=0 ; 1:R2=1 ; 2:R0=4 ; 2:R2=3 ; y=1"
"0:R0=0 ; 1:R0=2 ; 1:R2=1 ; 2:R0=4 ; 2:R2=3 ; y=1"
"0:R0=0 ; 1:R0=0 ; 1:R2=2 ; 2:R0=3 ; 2:R2=4 ; y=1"
"0:R0=1 ; 1:R0=0 ; 1:R2=2 ; 2:R0=3 ; 2:R2=4 ; y=1"
"0:R0=0 ; 1:R0=0 ; 1:R2=2 ; 2:R0=0 ; 2:R2=1 ; y=4"
"0:R0=0 ; 1:R0=2 ; 1:R2=4 ; 2:R0=1 ; 2:R2=3 ; y=4"
"0:R0=1 ; 1:R0=0 ; 1:R2=2 ; 2:R0=0 ; 2:R2=4 ; y=4"
"0:R0=0 ; 1:R0=1 ; 1:R2=2 ; 2:R0=3 ; 2:R2=4 ; y=4"
ARM LB+data+detrw-detw-ctrl "DpDatadW Rfe DetourRW DetourW DpCtrldW Rfe" Cycle=Rfe DetourRW DetourW DpCtrldW Rfe DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DetourRW DetourW DpCtrldW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; %y3=y; } P0 | P1 | P2 | P3 ; LDR R0,[%x0] | LDR R0,[%y1] | LDR R0,[%y2] | MOV R0,#4 ; EOR R1,R0,R0 | MOV R1,#3 | MOV R1,#2 | STR R0,[%y3] ; ADD R1,R1,#1 | STR R1,[%y1] | STR R1,[%y2] | ; STR R1,[%y0] | LDR R2,[%y1] | DMB | ; | CMP R2,R2 | LDR R2,[%y2] | ; | BNE LC00 | | ; | LC00: | | ; | MOV R3,#1 | | ; | STR R3,[%x1] | | ; Observed 0:R0=0; 1:R0=0; 1:R2=4; 2:R0=0; 2:R2=3; y=1; and 0:R0=0; 1:R0=0; 1:R2=1; 2:R0=4; 2:R2=3; y=1; and 0:R0=0; 1:R0=2; 1:R2=1; 2:R0=4; 2:R2=3; y=1; and 0:R0=0; 1:R0=0; 1:R2=2; 2:R0=3; 2:R2=4; y=1; and 0:R0=1; 1:R0=0; 1:R2=2; 2:R0=3; 2:R2=4; y=1; and 0:R0=0; 1:R0=0; 1:R2=2; 2:R0=0; 2:R2=1; y=4; and 0:R0=0; 1:R0=2; 1:R2=4; 2:R0=1; 2:R2=3; y=4; and 0:R0=1; 1:R0=0; 1:R2=2; 2:R0=0; 2:R2=4; y=4; and 0:R0=0; 1:R0=1; 1:R2=2; 2:R0=3; 2:R2=4; y=4;
