Executions for behaviour:
"0:R1=1 ; 1:R0=1 ; 1:R2=3"
ARM DETOUR0474 "PosWR Fri PodWW Rfe DpDatadW Wse" Cycle=Rfe DpDatadW Wse PosWR Fri PodWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=PosWR Fri PodWW Rfe DpDatadW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | EOR R1,R0,R0 ; LDR R1,[%x0] | ADD R1,R1,#1 ; MOV R2,#3 | STR R1,[%x1] ; STR R2,[%x0] | DMB ; MOV R3,#1 | LDR R2,[%x1] ; STR R3,[%y0] | ; Observed 0:R1=1; 1:R0=1; 1:R2=3;
