Executions for behaviour:
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 1:R5=0 ; 3:R0=0"
"1:R0=1 ; 1:R2=1 ; 1:R3=0 ; 1:R5=0 ; 3:R0=0"
"1:R0=1 ; 1:R2=0 ; 1:R3=1 ; 1:R5=0 ; 3:R0=0"
"1:R0=1 ; 1:R2=1 ; 1:R3=1 ; 1:R5=0 ; 3:R0=0"
"1:R0=1 ; 1:R2=0 ; 1:R3=0 ; 1:R5=0 ; 3:R0=1"
"1:R0=1 ; 1:R2=1 ; 1:R3=0 ; 1:R5=0 ; 3:R0=1"
"1:R0=1 ; 1:R2=1 ; 1:R3=1 ; 1:R5=0 ; 3:R0=1"
ARM MP+dmb+addr-bigdetour3-addr "DMBdWW Rfe DpAddrdR Leave Fre DMBdWW Rfe DpDatadW Back Rfe DpAddrdR Fre" Prefetch=0:x=F,0:y=W,1:y=F,1:x=T,2:z=F,2:a=W,3:a=F,3:b=W Com=Rf Fr Rf Rf Orig=DMBdWW Rfe DpAddrdR Leave Fre DMBdWW Rfe DpDatadW Back Rfe DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %z1=z; %b1=b; %x1=x; %z2=z; %a2=a; %a3=a; %b3=b; } P0 | P1 | P2 | P3 ; MOV R0,#1 | LDR R0,[%y1] | MOV R0,#1 | LDR R0,[%a3] ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%z2] | EOR R1,R0,R0 ; DMB | LDR R2,[R1,%z1] | DMB | ADD R1,R1,#1 ; MOV R1,#1 | LDR R3,[%b1] | MOV R1,#1 | STR R1,[%b3] ; STR R1,[%y0] | EOR R4,R3,R3 | STR R1,[%a2] | ; | LDR R5,[R4,%x1] | | ; Observed 1:R0=1; 1:R2=0; 1:R3=0; 1:R5=0; 3:R0=0; and 1:R0=1; 1:R2=1; 1:R3=0; 1:R5=0; 3:R0=0; and 1:R0=1; 1:R2=0; 1:R3=1; 1:R5=0; 3:R0=0; and 1:R0=1; 1:R2=1; 1:R3=1; 1:R5=0; 3:R0=0; and 1:R0=1; 1:R2=0; 1:R3=0; 1:R5=0; 3:R0=1; and 1:R0=1; 1:R2=1; 1:R3=0; 1:R5=0; 3:R0=1; and 1:R0=1; 1:R2=1; 1:R3=1; 1:R5=0; 3:R0=1;
