Executions for behaviour:
"1:R0=1 ; 1:R2=3 ; 1:R3=2 ; x=2"
"1:R0=0 ; 1:R2=4 ; 1:R3=2 ; x=2"
"1:R0=0 ; 1:R2=3 ; 1:R3=4 ; x=2"
"1:R0=0 ; 1:R2=2 ; 1:R3=3 ; x=3"
"1:R0=0 ; 1:R2=4 ; 1:R3=3 ; x=3"
"1:R0=0 ; 1:R2=3 ; 1:R3=2 ; x=4"
"1:R0=0 ; 1:R2=2 ; 1:R3=3 ; x=4"
"1:R0=0 ; 1:R2=2 ; 1:R3=4 ; x=4"
"1:R0=0 ; 1:R2=3 ; 1:R3=4 ; x=4"
ARM DETOUR0825 "DMBdWW Rfe DpDatadW DetourW DetourR Fre" Cycle=Rfe DpDatadW DetourW DetourR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpDatadW DetourW DetourR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; %x3=x; } P0 | P1 | P2 | P3 ; MOV R0,#4 | LDR R0,[%y1] | MOV R0,#2 | MOV R0,#3 ; STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%x2] | STR R0,[%x3] ; DMB | ADD R1,R1,#1 | | ; MOV R1,#1 | STR R1,[%x1] | | ; STR R1,[%y0] | LDR R2,[%x1] | | ; | LDR R3,[%x1] | | ; Observed 1:R0=1; 1:R2=3; 1:R3=2; x=2; and 1:R0=0; 1:R2=4; 1:R3=2; x=2; and 1:R0=0; 1:R2=3; 1:R3=4; x=2; and 1:R0=0; 1:R2=2; 1:R3=3; x=3; and 1:R0=0; 1:R2=4; 1:R3=3; x=3; and 1:R0=0; 1:R2=3; 1:R3=2; x=4; and 1:R0=0; 1:R2=2; 1:R3=3; x=4; and 1:R0=0; 1:R2=2; 1:R3=4; x=4; and 1:R0=0; 1:R2=3; 1:R3=4; x=4;
