Executions for behaviour:
"1:R3=1 ; 1:R4=0 ; x=2 ; y=2"
ARM DETOUR0947 "DMBdWW Wse PosWR DpAddrdR DetourR Fre" Cycle=Fre DMBdWW Wse PosWR DpAddrdR DetourR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Ws Fr Orig=DMBdWW Wse PosWR DpAddrdR DetourR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | MOV R0,#2 | MOV R0,#1 ; STR R0,[%x0] | STR R0,[%y1] | STR R0,[%x2] ; DMB | LDR R1,[%y1] | ; MOV R1,#1 | EOR R2,R1,R1 | ; STR R1,[%y0] | LDR R3,[R2,%x1] | ; | LDR R4,[%x1] | ; Observed 1:R3=1; 1:R4=0; x=2; y=2;
