Executions for behaviour:
"1:R0=1 ; 1:R1=2 ; 1:R2=0 ; 1:R3=1 ; x=1"
ARM DETOUR0718 "DMBdWW Rfe PodRR DetourR PosRR Fre" Cycle=Rfe PodRR DetourR PosRR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PodRR DetourR PosRR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | LDR R0,[%y1] | MOV R0,#1 ; STR R0,[%x0] | LDR R1,[%x1] | STR R0,[%x2] ; DMB | LDR R2,[%x1] | ; MOV R1,#1 | LDR R3,[%x1] | ; STR R1,[%y0] | | ; Observed 1:R0=1; 1:R1=2; 1:R2=0; 1:R3=1; x=1;
