Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; x=2"
ARM LB+PPO0592 "PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR" Cycle=Rfe PosRR PosRW PosWR PosRR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR { %y0=y; %x0=x; %x1=x; %y1=y; } P0 | P1 ; LDR R0,[%y0] | LDR R0,[%x1] ; EOR R1,R0,R0 | LDR R1,[%x1] ; ADD R1,R1,#1 | MOV R2,#2 ; STR R1,[%x0] | STR R2,[%x1] ; | LDR R3,[%x1] ; | LDR R4,[%x1] ; | MOV R5,#1 ; | STR R5,[%y1] ; Observed 0:R0=1; 1:R0=1; x=2;
