Executions for behaviour:
"0:R0=1 ; 1:R0=1 ; y=2"
ARM LB+PPO0528 "PodWW Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW" Cycle=Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW PodWW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWR PosRR PosRW { %z0=z; %x0=x; %x1=x; %y1=y; %z1=z; } P0 | P1 ; LDR R0,[%z0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%x0] | STR R1,[%y1] ; | LDR R2,[%y1] ; | LDR R3,[%y1] ; | MOV R4,#2 ; | STR R4,[%y1] ; | MOV R5,#1 ; | STR R5,[%z1] ; Observed 0:R0=1; 1:R0=1; y=2;
