Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0173 "PodWW Rfe DpDatadW Rfe DpDatadW PosWR DpDatadW PosWR DpDatadW" Cycle=Rfe DpDatadW Rfe DpDatadW PosWR DpDatadW PosWR DpDatadW PodWW Relax= Safe=Rfe PosWR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWR DpDatadW PosWR DpDatadW { %b0=b; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; %b1=b; } P0 | P1 ; LDR R0,[%b0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%x0] | STR R1,[%y1] ; | LDR R2,[%y1] ; | EOR R3,R2,R2 ; | ADD R3,R3,#1 ; | STR R3,[%z1] ; | LDR R4,[%z1] ; | EOR R5,R4,R4 ; | ADD R5,R5,#1 ; | STR R5,[%a1] ; | MOV R6,#1 ; | STR R6,[%b1] ; Observed 0:R0=1; 1:R0=1;
