Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0556
"PodRW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR"
Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR PodRW
Relax=
Safe=Rfe PosWR PosRR Pod*W DpAddrdR DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
P0 | P1 ;
LDR R0,[%a0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | CMP R0,R0 ;
ADD R1,R1,#1 | BNE LC00 ;
STR R1,[%x0] | LC00: ;
| MOV R1,#1 ;
| STR R1,[%y1] ;
| LDR R2,[%y1] ;
| LDR R3,[%y1] ;
| EOR R4,R3,R3 ;
| LDR R5,[R4,%z1] ;
| LDR R6,[%z1] ;
| MOV R7,#1 ;
| STR R7,[%a1] ;
Observed
0:R0=1; 1:R0=1;
