Executions for behaviour:
"0:R0=0 ; 1:R0=1 ; x=1"
"0:R0=0 ; 1:R0=2 ; x=1"
"0:R0=0 ; 1:R0=2 ; x=2"
ARM LB+PPO0511
"PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR PosRW"
Cycle=Rfe PosRR PosRW PosWR DpAddrdR PosRW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe PosRR PosRW PosWR DpAddrdR PosRW
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
P0 | P1 ;
LDR R0,[%z0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | LDR R1,[%x1] ;
ADD R1,R1,#1 | MOV R2,#2 ;
STR R1,[%x0] | STR R2,[%x1] ;
| LDR R3,[%x1] ;
| EOR R4,R3,R3 ;
| LDR R5,[R4,%y1] ;
| MOV R6,#1 ;
| STR R6,[%y1] ;
| MOV R7,#1 ;
| STR R7,[%z1] ;
Observed
0:R0=0; 1:R0=1; x=1;
and 0:R0=0; 1:R0=2; x=1;
and 0:R0=0; 1:R0=2; x=2;
