Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0410
"PodRW Rfe DpDatadW Rfe DpDatadW PosWR DpAddrdR DpDatadW PosWR"
Cycle=Rfe DpDatadW Rfe DpDatadW PosWR DpAddrdR DpDatadW PosWR PodRW
Relax=
Safe=Rfe PosWR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpDatadW PosWR DpAddrdR DpDatadW PosWR
%b0=b; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a; %b1=b;
P0 | P1 ;
LDR R0,[%b0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | EOR R1,R0,R0 ;
ADD R1,R1,#1 | ADD R1,R1,#1 ;
STR R1,[%x0] | STR R1,[%y1] ;
| LDR R2,[%y1] ;
| EOR R3,R2,R2 ;
| LDR R4,[R3,%z1] ;
| EOR R5,R4,R4 ;
| ADD R5,R5,#1 ;
| STR R5,[%a1] ;
| LDR R6,[%a1] ;
| MOV R7,#1 ;
| STR R7,[%b1] ;
Observed
0:R0=1; 1:R0=1;
