Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0408
"PodRW Rfe DpDatadW Rfe DpAddrdR DpDatadW PosWR"
Cycle=Rfe DpAddrdR DpDatadW PosWR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosWR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpAddrdR DpDatadW PosWR
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
P0 | P1 ;
LDR R0,[%a0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | EOR R1,R0,R0 ;
ADD R1,R1,#1 | LDR R2,[R1,%y1] ;
STR R1,[%x0] | EOR R3,R2,R2 ;
| ADD R3,R3,#1 ;
| STR R3,[%z1] ;
| LDR R4,[%z1] ;
| MOV R5,#1 ;
| STR R5,[%a1] ;
Observed
0:R0=1; 1:R0=1;
