Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0114
"PodWW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpAddrdW"
Cycle=Rfe DpAddrdR PosRW PosWR DpAddrdW PodWW Rfe DpDatadW
Relax=
Safe=Rfe PosWR PosRW Pod*W DpAddrdW DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodWW Rfe DpDatadW Rfe DpAddrdR PosRW PosWR DpAddrdW
%a0=a; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a;
P0 | P1 ;
LDR R0,[%a0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | EOR R1,R0,R0 ;
ADD R1,R1,#1 | LDR R2,[R1,%y1] ;
STR R1,[%x0] | MOV R3,#1 ;
| STR R3,[%y1] ;
| LDR R4,[%y1] ;
| EOR R5,R4,R4 ;
| MOV R6,#1 ;
| STR R6,[R5,%z1] ;
| MOV R7,#1 ;
| STR R7,[%a1] ;
Observed
0:R0=1; 1:R0=1;
