Executions for behaviour:
"0:R0=1 ; 1:R0=1"
ARM LB+PPO0022
"PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpCtrldW PosWR DpAddrdR"
Cycle=Rfe DpDatadW Rfe DpCtrldW PosWR DpCtrldW PosWR DpAddrdR PodRW
Relax=
Safe=Rfe PosWR Pod*W DpAddrdR DpDatadW DpCtrldW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpCtrldW PosWR DpCtrldW PosWR DpAddrdR
%b0=b; %x0=x;
%x1=x; %y1=y; %z1=z; %a1=a; %b1=b;
P0 | P1 ;
LDR R0,[%b0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | CMP R0,R0 ;
ADD R1,R1,#1 | BNE LC00 ;
STR R1,[%x0] | LC00: ;
| MOV R1,#1 ;
| STR R1,[%y1] ;
| LDR R2,[%y1] ;
| CMP R2,R2 ;
| BNE LC01 ;
| LC01: ;
| MOV R3,#1 ;
| STR R3,[%z1] ;
| LDR R4,[%z1] ;
| EOR R5,R4,R4 ;
| LDR R6,[R5,%a1] ;
| MOV R7,#1 ;
| STR R7,[%b1] ;
Observed
0:R0=1; 1:R0=1;
