Test DETOUR0219
Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R2=0 ; 1:R4=1"
Executions for behaviour: "0:R0=0 ; 1:R0=0 ; 1:R2=1 ; 1:R4=1"
Executions for behaviour: "0:R0=0 ; 1:R0=1 ; 1:R2=1 ; 1:R4=1"
ARM DETOUR0219
"DpDatadW Rfe DpAddrdR Fri Rfi DpAddrdW Rfe"
Cycle=Rfi DpAddrdW Rfe DpDatadW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DpAddrdR Fri Rfi DpAddrdW Rfe
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
 P0           | P1              ;
 LDR R0,[%x0] | LDR R0,[%y1]    ;
 EOR R1,R0,R0 | EOR R1,R0,R0    ;
 ADD R1,R1,#1 | LDR R2,[R1,%z1] ;
 STR R1,[%y0] | MOV R3,#1       ;
              | STR R3,[%z1]    ;
              | LDR R4,[%z1]    ;
              | EOR R5,R4,R4    ;
              | MOV R6,#1       ;
              | STR R6,[R5,%x1] ;
Observed
    0:R0=1; 1:R0=1; 1:R2=0; 1:R4=1;
and 0:R0=0; 1:R0=0; 1:R2=1; 1:R4=1;
and 0:R0=0; 1:R0=1; 1:R2=1; 1:R4=1;
