ARM MOREDETOUR0444 "DMBdWW Rfe DetourRW Wsi Rfi DpAddrdR Fre" Cycle=Rfi DpAddrdR Fre DMBdWW Rfe DetourRW Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DetourRW Wsi Rfi DpAddrdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | LDR R0,[%y2] ; STR R0,[%x0] | MOV R1,#3 | MOV R1,#2 ; DMB | STR R1,[%y1] | STR R1,[%y2] ; MOV R1,#1 | MOV R2,#4 | DMB ; STR R1,[%y0] | STR R2,[%y1] | LDR R2,[%y2] ; | LDR R3,[%y1] | ; | EOR R4,R3,R3 | ; | LDR R5,[R4,%x1] | ; Observed 1:R0=0; 1:R3=2; 1:R5=0; 2:R0=1; 2:R2=2;
