Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=3 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=2 ; x=2"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=1 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=1 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=2 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=0 ; 2:R2=3 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=0 ; 1:R4=1 ; 2:R0=4 ; 2:R2=3 ; x=3"
Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R4=1 ; 2:R0=0 ; 2:R2=4 ; x=3"
ARM MOREDETOUR0782
"DMBdWW Rfe DpAddrdR Fri Rfi DetourRW Wse"
Cycle=Rfi DetourRW Wse DMBdWW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe DpAddrdR Fri Rfi DetourRW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
P0 | P1 | P2 ;
MOV R0,#4 | LDR R0,[%y1] | LDR R0,[%x2] ;
STR R0,[%x0] | EOR R1,R0,R0 | MOV R1,#2 ;
DMB | LDR R2,[R1,%x1] | STR R1,[%x2] ;
MOV R1,#1 | MOV R3,#1 | DMB ;
STR R1,[%y0] | STR R3,[%x1] | LDR R2,[%x2] ;
| LDR R4,[%x1] | ;
| MOV R5,#3 | ;
| STR R5,[%x1] | ;
Observed
1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=3; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=2; x=2;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=1; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=2; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=1; 2:R2=2; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=2; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=0; 2:R2=3; x=3;
and 1:R0=1; 1:R2=0; 1:R4=1; 2:R0=4; 2:R2=3; x=3;
and 1:R0=1; 1:R2=2; 1:R4=1; 2:R0=0; 2:R2=4; x=3;
