ARM S+PPO732 "Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWW PosWR DpCtrldW" Cycle=Rfe PosRW PosWR DpAddrdW PosWW PosWR DpCtrldW Wse DMBdWW Relax= Safe=Rfe Wse PosWW PosWR PosRW DMBdWW DpAddrdW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWW PosWR DpCtrldW { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | MOV R1, #2 ; DMB | STR R1, [%y1] ; MOV R1, #1 | LDR R2, [%y1] ; STR R1, [%y0] | EOR R3,R2,R2 ; | MOV R4, #1 ; | STR R4, [R3,%z1] ; | MOV R5, #2 ; | STR R5, [%z1] ; | LDR R6, [%z1] ; | CMP R6, R6 ; | BNE LC00 ; | LC00: ; | MOV R7, #1 ; | STR R7, [%x1] ; Observed 1:R0=1; x=2; y=2; z=2;
