ARM MP+PPO253 "Fre DMBdWW Rfe PosRW PosWR DpAddrdR DpCtrlIsbdR" Cycle=Rfe PosRW PosWR DpAddrdR DpCtrlIsbdR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW DMBdWW DpAddrdR DpCtrlIsbdR Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRW PosWR DpAddrdR DpCtrlIsbdR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #1 | LDR R0, [%y1] ; STR R0, [%x0] | MOV R1, #2 ; DMB | STR R1, [%y1] ; MOV R1, #1 | LDR R2, [%y1] ; STR R1, [%y0] | EOR R3,R2,R2 ; | LDR R4, [R3,%z1] ; | CMP R4, R4 ; | BNE LC00 ; | LC00: ; | ISB ; | LDR R5, [%x1] ; Observed 1:R0=1; 1:R5=0; y=2;
