ARM LB+PPO0268 "PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW" Cycle=Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW PodWW Relax= Safe=Rfe PosWW PosWR Pod*W DpDatadW DpCtrldW Prefetch= Com=Rf Rf Orig=PodWW Rfe DpDatadW Rfe DpDatadW PosWW PosWR DpCtrldW { %a0=a; %x0=x; %x1=x; %y1=y; %z1=z; %a1=a; } P0 | P1 ; LDR R0,[%a0] | LDR R0,[%x1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | ADD R1,R1,#1 ; STR R1,[%x0] | STR R1,[%y1] ; | MOV R2,#2 ; | STR R2,[%y1] ; | LDR R3,[%y1] ; | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%z1] ; | MOV R5,#1 ; | STR R5,[%a1] ; Observed 0:R0=1; 1:R0=1; y=2;
