ARM DETOUR1271 "DMBdWW Wse PosWR Fri Rfi DpCtrldW Wse" Cycle=Rfi DpCtrldW Wse DMBdWW Wse PosWR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Ws Ws Orig=DMBdWW Wse PosWR Fri Rfi DpCtrldW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | MOV R0,#2 ; STR R0,[%x0] | STR R0,[%y1] ; DMB | LDR R1,[%y1] ; MOV R1,#1 | MOV R2,#3 ; STR R1,[%y0] | STR R2,[%y1] ; DMB | LDR R3,[%y1] ; LDR R2,[%y0] | CMP R3,R3 ; | BNE LC00 ; | LC00: ; | MOV R4,#1 ; | STR R4,[%x1] ; Observed 0:R2=1; 1:R1=1; 1:R3=3; x=2; and 0:R2=3; 1:R1=1; 1:R3=3; x=2;
