ARM DETOUR0305 "DpDatadW Rfe DpAddrdR Fri Rfi PosRW Rfe" Cycle=Rfi PosRW Rfe DpDatadW Rfe DpAddrdR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpAddrdR Fri Rfi PosRW Rfe { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; LDR R0,[%x0] | LDR R0,[%y1] ; EOR R1,R0,R0 | EOR R1,R0,R0 ; ADD R1,R1,#1 | LDR R2,[R1,%x1] ; STR R1,[%y0] | MOV R3,#1 ; | STR R3,[%x1] ; | LDR R4,[%x1] ; | MOV R5,#2 ; | STR R5,[%x1] ; Observed 0:R0=0; 1:R0=0; 1:R2=0; 1:R4=2; and 0:R0=2; 1:R0=0; 1:R2=0; 1:R4=2; and 0:R0=0; 1:R0=1; 1:R2=0; 1:R4=2;
