Executions for behaviour:
"0:R0=64 ; 1:R0=0"
ARM LB+PPO0536
"PodRW Rfe DpDatadW Rfe DpAddrdR PosRR"
Cycle=Rfe DpAddrdR PosRR PodRW Rfe DpDatadW
Relax=
Safe=Rfe PosRR Pod*W DpAddrdR DpDatadW
Prefetch=
Com=Rf Rf
Orig=PodRW Rfe DpDatadW Rfe DpAddrdR PosRR
%z0=z; %x0=x;
%x1=x; %y1=y; %z1=z;
P0 | P1 ;
LDR R0,[%z0] | LDR R0,[%x1] ;
EOR R1,R0,R0 | EOR R1,R0,R0 ;
ADD R1,R1,#1 | LDR R2,[R1,%y1] ;
STR R1,[%x0] | LDR R3,[%y1] ;
| MOV R4,#1 ;
| STR R4,[%z1] ;
Observed
0:R0=64; 1:R0=0;
