Executions for behaviour: "0:R0=1 ; 1:R0=1 ; 1:R3=0"
ARM DETOUR0185
"DpDatadW Rfe PosRR DpAddrdR Fri Rfe"
Cycle=Rfe PosRR DpAddrdR Fri Rfe DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DpAddrdR Fri Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
LDR R0,[%x0] | LDR R0,[%y1] ;
EOR R1,R0,R0 | LDR R1,[%y1] ;
ADD R1,R1,#1 | EOR R2,R1,R1 ;
STR R1,[%y0] | LDR R3,[R2,%x1] ;
| MOV R4,#1 ;
| STR R4,[%x1] ;
Observed
0:R0=1; 1:R0=1; 1:R3=0;
