Executions for behaviour: "0:R0=1 ; 1:R0=1 ; x=2"
Executions for behaviour: "0:R0=2 ; 1:R0=1 ; x=2"
ARM LB0066
"DpDatadW Rfe PosRR DpDatadW PosWW Rfe"
Cycle=Rfe PosRR DpDatadW PosWW Rfe DpDatadW
Relax=[Rfe,DpDatadW,Rfe]
Safe=PosWW PosRR DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DpDatadW PosWW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
LDR R0,[%x0] | LDR R0,[%y1] ;
EOR R1,R0,R0 | LDR R1,[%y1] ;
ADD R1,R1,#1 | EOR R2,R1,R1 ;
STR R1,[%y0] | ADD R2,R2,#1 ;
| STR R2,[%x1] ;
| MOV R3,#2 ;
| STR R3,[%x1] ;
Observed
0:R0=1; 1:R0=1; x=2;
and 0:R0=2; 1:R0=1; x=2;
