Executions for behaviour: "0:R0=1 ; 1:R0=1 ; y=2"
ARM LB0007
"DpDatadW Rfe PosRW PosWR DpAddrdW Rfe"
Cycle=Rfe PosRW PosWR DpAddrdW Rfe DpDatadW
Relax=[Rfe,DpDatadW,Rfe]
Safe=PosWR PosRW DpAddrdW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRW PosWR DpAddrdW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
LDR R0,[%x0] | LDR R0,[%y1] ;
EOR R1,R0,R0 | MOV R1,#2 ;
ADD R1,R1,#1 | STR R1,[%y1] ;
STR R1,[%y0] | LDR R2,[%y1] ;
| EOR R3,R2,R2 ;
| MOV R4,#1 ;
| STR R4,[R3,%x1] ;
Observed
0:R0=1; 1:R0=1; y=2;
