Executions for behaviour: "1:R0=1 ; 1:R3=3 ; 1:R6=2 ; x=2 ; y=3"
ARM S+dmb+fri-wsi-rfi-addr "DMBdWW Rfe Fri Wsi Rfi DpAddrdW Wse" Cycle=Rfi DpAddrdW Wse DMBdWW Rfe Fri Wsi Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMBdWW Rfe Fri Wsi Rfi DpAddrdW Wse { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | MOV R1,#2 ; DMB | STR R1,[%y1] ; MOV R1,#1 | MOV R2,#3 ; STR R1,[%y0] | STR R2,[%y1] ; | LDR R3,[%y1] ; | EOR R4,R3,R3 ; | MOV R5,#1 ; | STR R5,[R4,%x1] ; | DMB ; | LDR R6,[%x1] ; Observed 1:R0=1; 1:R3=3; 1:R6=2; x=2; y=3;
