Executions for behaviour: "1:R0=1 ; x=2"
ARM S+PPO780
"Wse DMBdWW Rfe PosRR DpCtrldW"
Cycle=Rfe PosRR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosRR DMBdWW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRR DpCtrldW
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | LDR R1, [%y1] ;
DMB | CMP R1, R1 ;
MOV R1, #1 | BNE LC00 ;
STR R1, [%y0] | LC00: ;
| MOV R2, #1 ;
| STR R2, [%x1] ;
Observed
1:R0=1; x=2;
