Executions for behaviour: "1:R0=1 ; x=2 ; y=2"
ARM S+PPO656
"Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWR DpCtrldW"
Cycle=Rfe PosRW PosWR DpAddrdW PosWR DpCtrldW Wse DMBdWW
Relax=
Safe=Rfe Wse PosWR PosRW DMBdWW DpAddrdW DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse DMBdWW Rfe PosRW PosWR DpAddrdW PosWR DpCtrldW
%x0=x; %y0=y;
%y1=y; %z1=z; %x1=x;
P0 | P1 ;
MOV R0, #2 | LDR R0, [%y1] ;
STR R0, [%x0] | MOV R1, #2 ;
DMB | STR R1, [%y1] ;
MOV R1, #1 | LDR R2, [%y1] ;
STR R1, [%y0] | EOR R3,R2,R2 ;
| MOV R4, #1 ;
| STR R4, [R3,%z1] ;
| LDR R5, [%z1] ;
| CMP R5, R5 ;
| BNE LC00 ;
| LC00: ;
| MOV R6, #1 ;
| STR R6, [%x1] ;
Observed
1:R0=1; x=2; y=2;
