Executions for behaviour: "1:R0=1 ; 1:R7=1 ; x=2 ; y=2"
ARM MP+PPO704 "Fre DMBdWW Rfe PosRW PosWR PosRR DpAddrdR DpCtrldW PosWR" Cycle=Rfe PosRW PosWR PosRR DpAddrdR DpCtrldW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdR DpCtrldW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRW PosWR PosRR DpAddrdR DpCtrldW PosWR { %x0=x; %y0=y; %y1=y; %z1=z; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | MOV R1, #2 ; DMB | STR R1, [%y1] ; MOV R1, #1 | LDR R2, [%y1] ; STR R1, [%y0] | LDR R3, [%y1] ; | EOR R4,R3,R3 ; | LDR R5, [R4,%z1] ; | CMP R5, R5 ; | BNE LC00 ; | LC00: ; | MOV R6, #1 ; | STR R6, [%x1] ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=1; x=2; y=2;
