Executions for behaviour: "1:R0=1 ; 1:R7=1 ; x=2 ; y=2"
ARM MP+PPO588 "Fre DMBdWW Rfe PosRR PosRW PosWR PosRR DpAddrdW PosWR" Cycle=Rfe PosRR PosRW PosWR PosRR DpAddrdW PosWR Fre DMBdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR DMBdWW DpAddrdW Prefetch=1:x=T Orig=Fre DMBdWW Rfe PosRR PosRW PosWR PosRR DpAddrdW PosWR { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0, #2 | LDR R0, [%y1] ; STR R0, [%x0] | LDR R1, [%y1] ; DMB | MOV R2, #2 ; MOV R1, #1 | STR R2, [%y1] ; STR R1, [%y0] | LDR R3, [%y1] ; | LDR R4, [%y1] ; | EOR R5,R4,R4 ; | MOV R6, #1 ; | STR R6, [R5,%x1] ; | LDR R7, [%x1] ; Observed 1:R0=1; 1:R7=1; x=2; y=2;
