Executions for behaviour: "1:R0=1 ; 1:R1=1 ; 1:R3=2 ; x=2"
ARM DETOUR1089
"DMBdWW Rfe PosRR Fri Rfi DpAddrdW Wse"
Cycle=Rfi DpAddrdW Wse DMBdWW Rfe PosRR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DMBdWW Rfe PosRR Fri Rfi DpAddrdW Wse
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0,#2 | LDR R0,[%y1] ;
STR R0,[%x0] | LDR R1,[%y1] ;
DMB | MOV R2,#2 ;
MOV R1,#1 | STR R2,[%y1] ;
STR R1,[%y0] | LDR R3,[%y1] ;
| EOR R4,R3,R3 ;
| MOV R5,#1 ;
| STR R5,[R4,%x1] ;
Observed
1:R0=1; 1:R1=1; 1:R3=2; x=2;
