Executions for behaviour: "1:R0=1 ; 1:R2=3 ; 1:R4=2 ; 1:R5=1 ; x=2"
ARM DETOUR0803
"DMBdWW Rfe DpAddrdR Fri Rfi DetourR Fre"
Cycle=Rfi DetourR Fre DMBdWW Rfe DpAddrdR Fri
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpAddrdR Fri Rfi DetourR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
P0 | P1 | P2 ;
MOV R0,#3 | LDR R0,[%y1] | MOV R0,#2 ;
STR R0,[%x0] | EOR R1,R0,R0 | STR R0,[%x2] ;
DMB | LDR R2,[R1,%x1] | ;
MOV R1,#1 | MOV R3,#1 | ;
STR R1,[%y0] | STR R3,[%x1] | ;
| LDR R4,[%x1] | ;
| LDR R5,[%x1] | ;
Observed
1:R0=1; 1:R2=3; 1:R4=2; 1:R5=1; x=2;
