Executions for behaviour: "1:R0=1 ; 1:R2=2 ; 1:R3=1 ; x=2"
ARM DETOUR0715
"DMBdWW Rfe DpCtrldW DetourW PosRR Fre"
Cycle=Rfe DpCtrldW DetourW PosRR Fre DMBdWW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe DpCtrldW DetourW PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
P0 | P1 | P2 ;
MOV R0,#3 | LDR R0,[%y1] | MOV R0,#2 ;
STR R0,[%x0] | CMP R0,R0 | STR R0,[%x2] ;
DMB | BNE LC00 | ;
MOV R1,#1 | LC00: | ;
STR R1,[%y0] | MOV R1,#1 | ;
| STR R1,[%x1] | ;
| LDR R2,[%x1] | ;
| LDR R3,[%x1] | ;
Observed
1:R0=1; 1:R2=2; 1:R3=1; x=2;
