Executions for behaviour: "1:R0=1 ; 1:R2=0"
ARM MP0107 "DMBdWW Rfe PosRR DpCtrlIsbdR Fre" Cycle=Rfe PosRR DpCtrlIsbdR Fre DMBdWW Relax=[Fre,DMBdWW,Rfe] Safe=PosRR DpCtrlIsbdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PosRR DpCtrlIsbdR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#1 | LDR R0,[%y1] ; STR R0,[%x0] | LDR R1,[%y1] ; DMB | CMP R1,R1 ; MOV R1,#1 | BNE LC00 ; STR R1,[%y0] | LC00: ; | ISB ; | LDR R2,[%x1] ; Observed 1:R0=1; 1:R2=0;
