Executions for behaviour: "0:R0=3 ; 0:R1=3 ; 0:R2=1 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=2"
Executions for behaviour: "0:R0=0 ; 0:R1=0 ; 0:R2=0 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 0:R1=0 ; 0:R2=1 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 0:R1=2 ; 0:R2=2 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 0:R1=2 ; 0:R2=3 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
Executions for behaviour: "0:R0=0 ; 0:R1=3 ; 0:R2=3 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
Executions for behaviour: "0:R0=3 ; 0:R1=3 ; 0:R2=3 ; 2:R0=1 ; 2:R2=2 ; 2:R3=0 ; y=3"
ARM MP+dmb+fri-rfi-ctrlisb+BIS+obs "DMBdWW Rfe Fri Rfi DpCtrlIsbdR Fre + Some write + observation" Prefetch=1:x=F,1:y=W,2:y=F,2:x=T Com=Rf Fr Orig=DMBdWW Rfe Fri Rfi DpCtrlIsbdR Fre { %y0=y; %x1=x; %y1=y; %y2=y; %x2=x; %y3=y; } P0 | P1 | P2 | P3 ; LDR R0,[%y0] | MOV R0,#1 | LDR R0,[%y2] | MOV R0,#3 ; DMB | STR R0,[%x1] | MOV R1,#2 | STR R0,[%y3] ; LDR R1,[%y0] | DMB | STR R1,[%y2] | ; DMB | MOV R1,#1 | LDR R2,[%y2] | ; LDR R2,[%y0] | STR R1,[%y1] | CMP R2,R2 | ; | | BNE LC00 | ; | | LC00: | ; | | ISB | ; | | LDR R3,[%x2] | ; Observed 0:R0=3; 0:R1=3; 0:R2=1; 2:R0=1; 2:R2=2; 2:R3=0; y=2; and 0:R0=0; 0:R1=0; 0:R2=0; 2:R0=1; 2:R2=2; 2:R3=0; y=3; and 0:R0=0; 0:R1=0; 0:R2=1; 2:R0=1; 2:R2=2; 2:R3=0; y=3; and 0:R0=0; 0:R1=2; 0:R2=2; 2:R0=1; 2:R2=2; 2:R3=0; y=3; and 0:R0=0; 0:R1=2; 0:R2=3; 2:R0=1; 2:R2=2; 2:R3=0; y=3; and 0:R0=0; 0:R1=3; 0:R2=3; 2:R0=1; 2:R2=2; 2:R3=0; y=3; and 0:R0=3; 0:R1=3; 0:R2=3; 2:R0=1; 2:R2=2; 2:R3=0; y=3;
