Executions for behaviour: "0:R1=1 ; 0:R2=2 ; 2:R0=0 ; 2:R2=1 ; x=1"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=0 ; 2:R2=1 ; x=1"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=1 ; 2:R2=1 ; x=1"
Executions for behaviour: "0:R1=1 ; 0:R2=2 ; 2:R0=0 ; 2:R2=1 ; x=3"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=0 ; 2:R2=1 ; x=3"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=1 ; 2:R2=1 ; x=3"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=0 ; 2:R2=2 ; x=3"
Executions for behaviour: "0:R1=1 ; 0:R2=2 ; 2:R0=0 ; 2:R2=3 ; x=3"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=0 ; 2:R2=3 ; x=3"
Executions for behaviour: "0:R1=3 ; 0:R2=2 ; 2:R0=1 ; 2:R2=3 ; x=3"
ARM WWC+LBs
"From DetourW PosRR DpCtrldW Rfe DpDatadW Wse, seen state features LB or WWC"
(* Observation on DETOUR0443 probably due to uniproc violation *)
Cycle=Rfe DpDatadW Wse DetourW PosRR DpCtrldW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Ws
Orig=DetourW PosRR DpCtrldW Rfe DpDatadW Wse
%x0=x; %y0=y;
%x1=x;
%y2=y; %x2=x;
P0 | P1 | P2 ;
MOV R0,#2 | MOV R0,#3 | LDR R0,[%y2] ;
STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ;
LDR R1,[%x0] | | ADD R1,R1,#1 ;
LDR R2,[%x0] | | STR R1,[%x2] ;
CMP R2,R2 | | DMB ;
BNE LC00 | | LDR R2,[%x2] ;
LC00: | | ;
MOV R3,#1 | | ;
STR R3,[%y0] | | ;
Observed
0:R1=1; 0:R2=2; 2:R0=0; 2:R2=1; x=1;
and 0:R1=3; 0:R2=2; 2:R0=0; 2:R2=1; x=1;
and 0:R1=3; 0:R2=2; 2:R0=1; 2:R2=1; x=1;
and 0:R1=1; 0:R2=2; 2:R0=0; 2:R2=1; x=3;
and 0:R1=3; 0:R2=2; 2:R0=0; 2:R2=1; x=3;
and 0:R1=3; 0:R2=2; 2:R0=1; 2:R2=1; x=3;
and 0:R1=3; 0:R2=2; 2:R0=0; 2:R2=2; x=3;
and 0:R1=1; 0:R2=2; 2:R0=0; 2:R2=3; x=3;
and 0:R1=3; 0:R2=2; 2:R0=0; 2:R2=3; x=3;
and 0:R1=3; 0:R2=2; 2:R0=1; 2:R2=3; x=3;
