Executions for behaviour: "1:R0=1 ; 1:R4=0"
ARM MP0142
"DMBdWW Rfe PosRR DpAddrdR PosRR Fre"
Cycle=Rfe PosRR DpAddrdR PosRR Fre DMBdWW
Relax=[Fre,DMBdWW,Rfe]
Safe=PosRR DpAddrdR
Prefetch=0:x=F,0:y=W,1:y=F,1:x=T
Com=Rf Fr
Orig=DMBdWW Rfe PosRR DpAddrdR PosRR Fre
%x0=x; %y0=y;
%y1=y; %x1=x;
P0 | P1 ;
MOV R0,#1 | LDR R0,[%y1] ;
STR R0,[%x0] | LDR R1,[%y1] ;
DMB | EOR R2,R1,R1 ;
MOV R1,#1 | LDR R3,[R2,%x1] ;
STR R1,[%y0] | LDR R4,[%x1] ;
Observed
1:R0=1; 1:R4=0;
