Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=0 ; 2:R0=0 ; y=1"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 2:R0=0 ; y=1"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0 ; 2:R0=0 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 2:R0=0 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0 ; 2:R0=1 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 2:R0=1 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0 ; 2:R0=3 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 2:R0=3 ; y=2"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0 ; 2:R0=0 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=0 ; 2:R0=0 ; y=3"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 2:R0=0 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 2:R0=0 ; y=3"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=0 ; 2:R0=1 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=0 ; 2:R0=1 ; y=3"
Executions for behaviour: "1:R0=1 ; 1:R1=0 ; 1:R3=1 ; 2:R0=1 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=0 ; 1:R3=1 ; 2:R0=1 ; y=3"
Executions for behaviour: "1:R0=2 ; 1:R1=1 ; 1:R3=1 ; 2:R0=1 ; y=3"
ARM MOREDETOUR0478 "DMBdWW Rfe PosRR DetourRW PodWR Fre" Cycle=Rfe PosRR DetourRW PodWR Fre DMBdWW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe PosRR DetourRW PodWR Fre { %x0=x; %y0=y; %y1=y; %x1=x; %y2=y; } P0 | P1 | P2 ; MOV R0,#1 | LDR R0,[%y1] | LDR R0,[%y2] ; STR R0,[%x0] | LDR R1,[%y1] | MOV R1,#2 ; DMB | MOV R2,#3 | STR R1,[%y2] ; MOV R1,#1 | STR R2,[%y1] | ; STR R1,[%y0] | LDR R3,[%x1] | ; Observed 1:R0=2; 1:R1=0; 1:R3=0; 2:R0=0; y=1; and 1:R0=2; 1:R1=0; 1:R3=1; 2:R0=0; y=1; and 1:R0=1; 1:R1=0; 1:R3=0; 2:R0=0; y=2; and 1:R0=1; 1:R1=0; 1:R3=1; 2:R0=0; y=2; and 1:R0=1; 1:R1=0; 1:R3=0; 2:R0=1; y=2; and 1:R0=1; 1:R1=0; 1:R3=1; 2:R0=1; y=2; and 1:R0=1; 1:R1=0; 1:R3=0; 2:R0=3; y=2; and 1:R0=1; 1:R1=0; 1:R3=1; 2:R0=3; y=2; and 1:R0=1; 1:R1=0; 1:R3=0; 2:R0=0; y=3; and 1:R0=2; 1:R1=0; 1:R3=0; 2:R0=0; y=3; and 1:R0=1; 1:R1=0; 1:R3=1; 2:R0=0; y=3; and 1:R0=2; 1:R1=0; 1:R3=1; 2:R0=0; y=3; and 1:R0=1; 1:R1=0; 1:R3=0; 2:R0=1; y=3; and 1:R0=2; 1:R1=0; 1:R3=0; 2:R0=1; y=3; and 1:R0=1; 1:R1=0; 1:R3=1; 2:R0=1; y=3; and 1:R0=2; 1:R1=0; 1:R3=1; 2:R0=1; y=3; and 1:R0=2; 1:R1=1; 1:R3=1; 2:R0=1; y=3;
