Executions for behaviour: "1:R0=0 ; 1:R1=0 ; 1:R3=2 ; 1:R4=1 ; x=2"
ARM MOREDETOUR0468 "DMBdWW Rfe DpCtrldR Fri Rfi PosRR Fre" Cycle=Rfi PosRR Fre DMBdWW Rfe DpCtrldR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMBdWW Rfe DpCtrldR Fri Rfi PosRR Fre { %x0=x; %y0=y; %y1=y; %x1=x; } P0 | P1 ; MOV R0,#2 | LDR R0,[%y1] ; STR R0,[%x0] | CMP R0,R0 ; DMB | BNE LC00 ; MOV R1,#1 | LC00: ; STR R1,[%y0] | LDR R1,[%x1] ; | MOV R2,#1 ; | STR R2,[%x1] ; | LDR R3,[%x1] ; | LDR R4,[%x1] ; Observed 1:R0=0; 1:R1=0; 1:R3=2; 1:R4=1; x=2;
